elect.chock
Here is a Post I made a while back. May be it will help.Read the hole thing before you delete it.
can't tune chock
Here is something that you might want to take a look at: This got me to thinking because, you said it only dose it in the morning when it was cold out side. In the morning go out to the car and then:
(1) Do not get in the car only to release the hood latch. And do not touch the gas peddle Do not turn the key on.
(2) now you are out side looking in the engine compartment. Remove the air cleaner (be careful to not touch the throttled linkage) With a flash lite look down the throat of the Carburetor (the chock plat should be open wide, don't touch it! Till you later why.) If it is real wet with gas down in the bottom of the intake manifold, then the carburetor has drained down after it set's for a long time. (could be the economize valve leaking) This will cause a hard to start, or at lest a longer time to start because it must pump the gas back in the reservoir of the carburetor. It could also cause it to back fire, wash the cylinder walls down, and May even drain gas in to the crank case. But after you get ti to run for a bit,it must likely will run fine and be normal.
(3) If you did not find any thing wrong as listed above, then:
(a) Get in the car and before you turn the key on, steep on the gas peddle real hard and then release it real quick ONE TIME and no more. Now go back out side and look at the chock plat. Is it closed? ( it should be fully closed) If not then the chock needs adjusted so that it well close when cold and after the gas peddle has released it from its wide open position .( the adjusting screw on the steps of the linkage cam is what the peddle releases)( when warm it should be on the bottom step of the cam, when cold and before you touch the gas peddle it is also in this position. But one hard step on the gas peddle and the chock plat should close tight and the cam adjusting screw will move to the high point of the cam) If this is not the way it works, then you need to adjust it till it does.
(4) Now this is why I said not to turn the key on:
(a) If it has an electric chock, when you turn the key on the element in the chock housing starts to warm up and it get hot real quick. So if you have to crank on the engine for a while to get the gas to the reservoir, the chock is all ready hot and is wide open. And wont start right away. So you pump a little more on the gas peddle and then you got to much gas and it back fires and doesn't run very good till it clears it's self out.
I think electric chocks are a pain. But if you don't actuate the chock plat, even the spring loaded chock wont work right. ------------------------------------------------Just something to think about! ------- Gene Neal
