Welcome to my nightmare.
I got an Edelbrock Pro Flo system for my 355 Chevy in early-mid September of last year.
I called Edelbrock first before buying the system because I have an old race motor with a cam that makes almost no vacuum at idle and 12.5:1 compression. They told me there'd be no problem, they could make me a chip that would work fine. So I bought the system from Summit on September 7 of last year along with the Mallory EFI distributor that Edelbrock recommended.
I got it installed and the car started right up. It ran a couple minutes and I shut it off and called Edelbrock to get some tune up help. I made the adjustments to the car with an Edelbrock tech guy on the phone. We got done. I shut the car off. I started it the next day, it ran no more than five minutes and died.
That was the beginning of replacing every single part that Edelbrock tech could think of -- some parts multiple times. For instance, 5 coils, 2 starters, 3 batteries, 3 ignition modules and so on.
I called American Autowire during all of this and they went through my entire wiring job checking for any possible problems with my installation of their kit and we found nothing wrong.
After replacing pretty much everything else on the car except the main computer/chip, we finally got to the point where I replaced the brand new Mallory EFI distributor that I'd purchased at Edelbrock's recommendation at the same time I got the EFI system, and bought a $100 Summit HEI. While installing the HEI, the larger diameter distributor snapped off the oil pressure gauge fitting in the top of the block. It was old and probably corroded. This was about early December, late November.
That was it for me. I'd had 6 or 7 weeks of nonsense and $900 more down the drain trying to make my car run and so I took the car to a shop.
I had 2 ignition modules in the car. The original that came with the kit and a second one that Edelbrock had sent me. They checked both of the Edelbrock supplied ignition modules (Edelbrock calls them "Ignition Amplifiers") and both were bad. One was dead, one was nearly dead.
The shop installed an AC-Delco brand part and installed the HEI, fixed the oil pressure fitting and the car ran fine....until today.
It's got no more than 50 minutes of running time - in the garage, no driving - since it came back from the shop. Today I ran it maybe 5 minutes while I took a video of it and it just shut off. It just stopped as if I'd turned the key off. No warning signs.
I took the ignition module out and brought it over to the shop to be tested. They can't do that until tomorrow. But if that's the problem, I don't know what could be killing ignition modules. I'd be happier if there were something else wrong this time.
Here's some specs: 355 Chevy, 12.5:1 compression, unknown cam (it gets about 8" vacuum at 1200 RPMs, American Autowire Highway 15 wiring kit, Optima battery, Summit HEI, Edelbrock Pro-Flo 3500 with 1000 CFM throttle body (It's Summit part number EDL-3500), new Accel plug wires, new AC Delco plugs - provided by me, but installed at the shop.
If it's the module, does anyone know what would burn them out so fast?
I've got over $4,000 (more than I paid for the car), in this thing now and I can't keep doing this. It's going on eBay soon if it doesn't start working right. (The EFI, not the car. I'm keeping the car.
