I am running my vacuum for my brakes off the rear of my Carb. (Edelbrock 1405). However, I am running into a strange issue. The hole size is 5/16" so I bought brake line tubing that is pre- flared cut it to size and bent the way I need it. Here's the issue, I tighten down the fitting into the carb port, and although it is all the way in I can move the tube back and forth about 1/4-1/2". I hopoe that makes sense.
Is there a way to make the brake line snug in the carb. port?
Just seeing what you all think before I start cramming brass fittings in there before I adapt my line.
