I just converted my 72 Chevy 350 from an Edelbrock 600 cfm with EPS Performer intake to a stock GM aluminum intake with a Jet Performance Stage II Quadrajet. I tried using a carb adapter but was not getting the performance so I changed manifolds. The Q-jet does not have the throttle response that the Edelbrock did. I was using a 4 hole spacer on the Edelbrock but don't have one for the Q-jet. I plan on using a spacer of at least 1" hoping to increase torque and throttle response. Is 1" enough with the stock manifold? Is there something else I need to look at to help cure the lack of throttle response when cruising. I set up the Q-jet for maximum vacuum. I am at about 16 to 17 inches at 700rpm which is slightly better than with the Edelbrock. I have not changed the timing. I am at 14 initial with 36 with vacuum and about 51 total with mechanical.
Another odd thing happened when adjusting the carb. It was at about 1 turn out when I got it. I did have a ported vacuum source but after I opened it up to 3 turns I lost the ported vacuum. It now has full manifold vacuum at the connection that was ported.
