1 - 9 of 9 Posts
OK I am really stupid when it comes to wiring can I put the wire to my choke to the wiper fuse in my fuse block if not could someone please tell me if I can put it on any fuse I know nothing about electrical things.
Thank you
reply
Doc here::pimp:
See my reply in the first thread you started.
Doc:pimp:
Choke
Doc here:pimp:
Not upset at all:D :thumbup: :D
Just didn't see the need to type all that twice...:smash:
I'm basically lazy!:cool:
Doc :pimp:
Electric Choke
Hay Goat. Your electric choke should be hooked directly to a wire coming off the alternator. The reason being you only want power at this wire when and only when the car is running. You can check very easily which wire on the alt. is the correct one with a simple test light. Key on Engine Not Running,Check for power at any wires coming out of the Alt. P/S leave everything plugged in. You should find one or two hot and one with no power. Now start the engine and check the wire which seemed to have no power prior to starting the engine. If that wire is now with power you can connect it directly to the Electric Choke.
goat please go back to the 1-05 post titled -"scrap regulator"
in there Doc laid out a simple diagram on how to wire an electric choke.this.
Barry
btw I think Doc may you and me confused
1 - 9 of 9 Posts
