Multiply .7854 x 4.165 x 4.165 x 3.75 x 8 and find 408.73 cubic inches. The length of the connecting rod has nothing to do with figuring the cubic inch displacement of a motor.willrace said:I have a 70 model .040 400 sbc 3.75 stroke and a 6 in rod what is my cubic inch displacment?
Torque454 said:The 400 SBC didnt exist in 1970. I dont envy you running a .040 over 400 SBC tho if thats what you have. Sounds like it will be prone to overheating even worse than a stock 400 is. QUOTE]
Yes, it did, 1970 was the first year for the 400 SBC.
...And the 400 overheating myth lives on, I've run them .020, .030, .040, and .060 over, and with half fills of block filler, none of them have had an overheating issue, neither have the ones friends have used. It's all about the cooling system, since it is a big block sized Small Block, it needs a cooling system to match. Factory high flow air conditioning spec water pump(it has a better impeller) and clutch fan and at least a 3-core factory rediator with a shroud. Put it behind a radiator meant for a 307 and with a plain sheetmetal impeller pump of course it will overheat, just like a 396 will with the same radiator. You are cooling tha same # of cubic inches.
I'm getting tired of people repeating the same old "overheating 400" BS just because of their lack of knowledge. If your 400 overheats, it's because you don't know what you're doing.
"Wrong" 400 started 1970 to 1973 as a 4 bolt main motor. P/N 3951509. From 74 on up 2 bolt main
lg1969 said:OK I just looked it up and you are right. I have never ever seen or heard of a 1970 400 SBC tho.Torque454 said:The 400 SBC didnt exist in 1970.
I guess it just shows what you know. Nothing more than a factory copper-brass 3 row rad, an AC application waterpump and a 7 blade factory AC clutch fan, and the factory shrouds. Never get hot even with a half block hard block fill. These are Street/Strip engines, circle track may be a different story. Racers who know more than the average ******* shade tree mechanic actually go looking FOR the 400 smallblocks because bigger cubes is bigger power. That's ok though, stick to the smaller small blocks, that just leaves more of the coveted 400's for me. I don't like building a small block smaller than a 400, only do a 383 if I can't find a good 400 block core.Torque454 said:All I can say is it must have a FLAWLESS cooling system. Large squeeky clean aluminum radiator, high volume pump, and a large fan with lots of blades and a d*mn good clutch. The 400 SBC has half the ability to cool itself than any other SBC has. There is NO water jacket between the cylinders. That means half of each cylinder doesnt get adequate cooling. Oil changes are probably more critical too because half that cylinder will be alot hotter than the rest, causing some thermal breakdown. The cylinder heads were also steam cooled in alot of places rather than coolant cooled. And why do you think the 400 SBC was only produced something like 5 years? (i thought it was 9 years, ending in 1980 but i cant find any application that had a 400 early than 75, and later than 80 so it must have only been made for 5 years). If it was so great, the 400 would be the choice engine of most people rather than a 350, and the factory would have continued to produce it. That alone convinces me that they are problematic and having no water jacket surrounding the cylinders and steam cooled heads sounds like the problem to me. For racing only it might be ok, but i wouldnt expect to put it on the street, daily driven, sitting in traffic, on long trips, towing trailers, etc and certainly not expect it to live a long full life.
You may not have problems but the 400 didnt get that overheating reputation for no reason. It is an overheating prone engine and thats why its not made anymore. Thats why no one runs them, they take a 400 crank and stuff it in a 350 block and IMO thats probably the best way to go.
So you are saying the world is wrong and you are right? The word on the street is the 400 sbc is overheating prone. Just because you yourself have been lucky enough to not have problems with one doesnt mean they are the GOD of all small block chevys and that everyone else is wrong. The stopped making them because they were prone to problems. Im sure there were other reasons, but id say thats the big one. Its an oddball engine with overheating tendencys. As for running them with block filler, alot of race engines have filler in them. Some of them are filled completely up and have no cooling system at all. You can run an engine down the track and not have overheating problems. But put that engine in a truck, pulling a heavy trailer on a 100 degree day with AC on in the mountains and tell me it has no problems whatsoever staying cool. The damn 400 got a reputation for overheating for a reason. If everyone has problems keeping cooling systems working properly then why arent 350s and other SBCs having problems? Whats the difference? The siamesed cylinders and steam cooled heads. That alone says that the 400 has a problem with overheating. You shouldnt have to keep everything perfect all the time in order for it to stay cool. You are pushing the cooling system to its max with little room for problems and thats simply put, a bad idea.ericnova72 said:I guess it just shows what you know. Nothing more than a factory copper-brass 3 row rad, an AC application waterpump and a 7 blade factory AC clutch fan, and the factory shrouds. Never get hot even with a half block hard block fill. These are Street/Strip engines, circle track may be a different story. Racers who know more than the average ******* shade tree mechanic actually go looking FOR the 400 smallblocks because bigger cubes is bigger power. That's ok though, stick to the smaller small blocks, that just leaves more of the coveted 400's for me. I don't like building a small block smaller than a 400, only do a 383 if I can't find a good 400 block core.
The 400 got it's bad rep undeservedly from people not keeping the cooling system clean and replacing water pumps and radiators with incorrect application parts only adequate for the smaller SBC's. Part of that is the fault of the parts stores listing almost all SBC parts as being the same. The 400 was made for 10 full years and got phased out due to emission regulations and corporate downsizing, not because it was a problem engine.
The Dart blocks are just 400 blocks with more metal everywhere and priority main oiling revisions. They have siamese bore waterjackets too, even the ones with a 4" bore. Are They junk and "overheaters" too for that reason??
I just hate bogus BS second hand shade tree information that has no basis in real facts, not trying to jump on you Torque454, just setting the record straight for others. :thumbup:
Have you ever owned a 400 SBC?? You revealed your lack of intelligence on this subject with the "steam cooled heads" comment. Who's "word on the street", because everyone I know knows that the "word on the street" (according to your version) is totally the result of operator error and lack of knowledge. Go ahead and believe what you want, I can see providing you with real information on this is like talking to a fencepost. I bet you'll turn down a free 502 if it is ever offered to you too because it is a siamese bore engine and prone to overheatTorque454 said:So you are saying the world is wrong and you are right? The word on the street is the 400 sbc is overheating prone. Just because you yourself have been lucky enough to not have problems with one doesnt mean they are the GOD of all small block chevys and that everyone else is wrong. The stopped making them because they were prone to problems. Im sure there were other reasons, but id say thats the big one. Its an oddball engine with overheating tendencys. As for running them with block filler, alot of race engines have filler in them. Some of them are filled completely up and have no cooling system at all. You can run an engine down the track and not have overheating problems. But put that engine in a truck, pulling a heavy trailer on a 100 degree day with AC on in the mountains and tell me it has no problems whatsoever staying cool. The damn 400 got a reputation for overheating for a reason. If everyone has problems keeping cooling systems working properly then why arent 350s and other SBCs having problems? Whats the difference? The siamesed cylinders and steam cooled heads. That alone says that the 400 has a problem with overheating. You shouldnt have to keep everything perfect all the time in order for it to stay cool. You are pushing the cooling system to its max with little room for problems and thats simply put, a bad idea.
With all this said im sure the 400 is probably fine for racing only and maybe daily driving but forget making it WORK in the heat and be reliable. Thats what matters to me and the majority of people that want a truck. Even people with a car that would have a 400 in the real would would be sitting in traffic in the car in the heat with the AC going and probably easily have issues.
Ayuh,... Just What the 'ell are you talking about,..??..??Torque454 said:The 400 SBC has half the ability to cool itself than any other SBC has. There is NO water jacket between the cylinders. That means half of each cylinder doesnt get adequate cooling. Oil changes are probably more critical too because half that cylinder will be alot hotter than the rest, causing some thermal breakdown. The cylinder heads were also steam cooled in alot of places rather than coolant cooled. That alone convinces me that they are problematic and having no water jacket surrounding the cylinders and steam cooled heads sounds like the problem to me.
Stewie to Brian, as Brian sings a line of a song, "Who sings that?"techinspector1 said:She's so fine, my four-oh-nine.... :thumbup:
I'm with TI on this. In apps where a 350's cooling would have been marginal- a 400 would naturally be over taxing the cooling systemI'm betting that the bad rap was started and kept alive by backyard mechanics who bolted 350 heads onto 400 blocks and then spit out the head gaskets from overheating because the heads were not drilled for steam holes. Well, that and using a low performance water pump.
