I've got a ? about some assembly lube that i have and need to know if it's worth useing on the camshaft for break'in. What i've got is a small tube of red Torco engine lube that came with the KB piston's, Plus i've got a 2 oz. tube of Coastal anti-seize assembly lube i got a Autozone. I've also got the 5/8 fl. oz. Compcams Pro cam @ lifter lube, that came with the cam that i had purchased at Summitracing, it's in a little black sqweeze packet. The shop guy that did my block work told me that what he put's on the bearing's is STP, but im not sold on that idea myself even though he's been building engine's close to 30 yr's. I'm not sure if i should just dip the piston's in oil, or stick assembly lube on them, and some of the complaint's i here about
compcams red assembly lube make's me wonder what i should use for the cam break-in.
(Please Advise)
