Okay, seriously though. The engine is an original counter replacement 350hp 327 that I did an at home re-ring job on. Heads are 882 lightweight castings that I did some mild porting and valve unshrouding on. They were gone through at the machine shop before I got them. The block had NO ridge and little to no wear in the cylinders. New Sealed Power moly rings after the ball hone job, all new bearings including cam bearings and all new block plugs, etc. Flat tappet cam so I did the usual break in drill (engine fired immediately and kept it between 2k and 2.5k varying rpm for 25 min to beak in cam) and everything seemed to go well. Cut open the filter and no flakes, only minimal glitter in the bottom of the drain pan. I put about 30 miles on it tonight. I've been varying rpm, never really letting it get below 2k except at stop signs. Also been holding it in second gear from time to time and giving it 2/3 throttle or so to load the rings.
Any other advise in breaking the engine in? I planned on hitting the drag strip this weekend. I figure that's not much different than the dyno pulls that are done with new engines? Am I asking for trouble?
