Hi and thank you for looking at my thread, I may have a simple or a difficult problem with an engine build its a custom engine I am trying to stoke an engine for a larger displacement but I have hit a wall..
my question is
I have a toyota crankshaft 48mm main journals and 44mm connecting rod journals the custom rods that I am using are 45mm (large end) so they work out to be about 1mm larger, can I have custom thicker rod bearings made for this engine or MUST I weld crankshaft I would hate to have to buy NEW rods for just 1mm difference
All answers welcome and if anyone has a machine shop that can preform the welding I am located in NJ but I can ship out if needed a rough estimate for the service
Thank you so much
David
my question is
Thank you so much
David
