OK, so I got my block back from the machine shop and all is ready for assembly. I plastigaged the mains without problems. Plastigage read, guessing, .0018 (the squished strip was slightly larger than the .002 strip). The problem I'm running into is getting the caps off of the connecting rods. The rods have new ARP bolts pressed in and the big end was resized. I tried using my 16 oz. rubber mallet to bang them off but they wouldn't budge. I did manage to get one off but I was getting pretty irritated that they're so hard to get off. The one cap I did manage to get off, piston #1, I put in the engine to plastigage and I had a hell of a time getting it off to even check the squished plastigage strip. When I did manage to put the cap off it fell on the ground putting a couple dings in the cap and the bearing. So the set of bearings are now useless.
I ordered a brass hammer to help with the removal of the caps and hopefully all goes well. My questions.
1) The cap that fell on the ground got a couple of little dings in it from the concrete floor. Is smoothing these out by hand with sand paper acceptable?
2) Can you guys give me some tips how to remove the caps?
3) They seem darn near impossible to get off. Should I take them back to the machine shop to have them remove them and possibly do something to them to make them easier to remove? The rotating assembly was balanced so I don't want any work that'll throw that off.
4) How do I get a good plastigage reading preassembling the rods? I put the plastigage in the rod and not the caps, and I secured the crank using some vise grip pliers and tape, but I still seem to be getting a bad reading from having a hard time removing the cap. It's getting small from pulling and tapping with a rubber mallet.
Help...thanks in advance.
:thumbup:
:thumbup:
