OK I've been going in circles on this for a while and it's starting to get old. I've got a freshly rebuilt '64 352 FE block in my '68 Jeep M715. I've gone over everything I can think of and asked everyone I know so now I'm hoping the internet might turn up some answers. I've checked fuel, timing(mechanical and distributor), ignition parts, vacuum leaks, compression, vacuum gauge readings, filters, etc. The truck has been redone from the ground up so most everything of importance is brand new. I only have about 150 miles on it.
So the problem is that after the motor hits operating temperature and is being driven I get a loss in power and the motor will cut off if I let up on the accelerator for any reason(this makes shifting interesting). It takes about 5-10 minutes after the motor hits temp for this to happen, it's not an instant thing. When it shuts off I can either pop the clutch or crank it over with the starter and she'll fire right up and run. At this point as long as I let the motor idle I get no other shutting off issues. Now sometimes, but not always, I'll get a little bit of engine "rattle" while the truck is being driven once it starts doing the shut-off thing. Now if I'm just letting the truck idle for a long period of time, like when I'm checking things out, I don't get the shutting off issue at all. Even when I goose it every so often. Operating temp seems to be 200*, the motor stays right there or a bit lower. It doesn't seem to be over heating.
Engine specs are: 1964 Ford 352FE .040 over bore, single point distributor, stock 4v valves and ports, heads milled .020", deck milled .010", TRW cast pistons(advertised to drop comp ratio from 11:1 to 9:1 for modern fuel), Clevite RV cam, Weiand aluminum intake, 1" intake spacer, 180* t-stat, Sanderson shorty headers, Holley 600cfm vacuum secondary e-choke carb with #72 primary jets, MSD coil, Autolite #45 plugs, idle set to 650RPM, base timing 10*, full advance of 30* at aprox. 3500 RPM and up, mechanical fuel pump for 4brl FE.
I think that's all of the important stuff. I'm using a NV4500 transmission, NP201 transfer case, and still have the stock 5:87 gear in the axles with 36" tires. I run right around 2k RPM at 45MPH.
Any ideas what I should check? I'm about ready to pull the darn motor and drop it in a deep hole.
