84TA406 said:
My whole heater system is fine less the blower motor not being hooked up yet since its a new A/C delete box. I was just curious since I saw a lot of older cars with just the end sticking out of the firewall. Wasnt sure if it was laziness or gave some kind of performance advantage etc. Wouldnt keeping the heater systems allow an engine to stay cooler? I know when the heat goes on the engine temps should cool.
An old drag racing "trick" is to run the heater wide open on the return trip to start the cool-down.
Most of the time, there is no real good reason to
not use the heater, other than one less thing that can go wrong- heater hose leaking/blowing off, heater core leaking, that kind of thing.
If it's a DD, I would use the heater- if for nothing else, as a defroster to defog the windshield on those mornings that it's needed. But it's still nice to have some toasty, warm air coming from the vents when it's 30 degrees outside.
Track only (or mainly)? Who cares- delete it.
