Hey Gang...
Wouldn't you kow it...I FINALLY get my Rod project done, and now the engine is knocking! Arg!
ain:
Anyways, I am at a bit of a loss in diagnosing the source of the know. Here's the info...maybe some of you guys could give me an idea...
The engine is a solid lifter, .30 over 1965 Plymoouth 273ci with an a833 4 speed.
It has an aftermarket rear-sump oil pan and pickup tube.
The sound is a loud knocking which is heard loudest throught the stethoscope at the back of the oil pan (nearest to the tans). Sounds like the crank is hitting something. I drained the oil and dropped the pan thinking that the crank was hitting the oil pickup tube..not so. There is NO sign of the crank touching anything.
Checked the oil pump (ie. took it out and spun it manually), checked that the pickup tube was tight, checked the thrush bearing...no wear...
No metal chunks in the pan
Checked the play in the crank...less than 16th of inch lateral play.
Checked the sparkplug wires
Flywheel is on tight, no leak in exhaust manifolds.
Not a valve issue, as engine runs perfectly when it's knocking.
Running 35-40lbs of oil pressure, so I don't think it's main bearings.
The odd bit is...when you engage the clutch (ie. the flywheel is being pushed forward) the noise almost completely disappears! Returns when clutch is released.
The next step is to check all the rod bearings.
I REEEEAAAALLLLLYYY don't want to have to disassemble the front end again to remove the motor! I am hoping that maybe one of you guys will know exactly what it is, and that I can fix it while it's in the car.
Any info would be great. If one of you guys have a definative idea, I can snap a movie of the troublesome knock.
Thanks!!!!
Ty
Thanks!!!!
Ty
