Wel the time has come for me to buy my rebuild kit for my blown 355ci sbc. I'll tell you my plans and you tell me your thoughts.
350, 4 bolt, bored 030 over
Steel crank n rods
5 qt oil pan, steel 8 inch balancer, electric water pump n dual fans.
TRW forged dish blower pistons, moly rings, dbl roller chain, hi volume oil pump, fel pro gaskets.
Heres my cam choices. 488X292, [email protected] and 114 lobe seperation, or 452X284, [email protected] with 114 lobe seperation.(Not sure the rpm's, but Im using a PAW grind like Briansboy used).
Heads will be either ported big valve 882's with 76cc chambers, or ported 434's with 64cc chambers.
Should I run 7.5-1 comp or 8.5-1 comp on a street motor? I heard some say the lower compression is better with more boost, but Ive heard that a little higher comp with lower boost is better for the street????
2 Edelbrock 750's or 600's??? MSD ignition, I think I'll try the rear dump S-10 headers and I have a friend with a muffler shop that can hook me up with either 2.5 or 3 inch exhuast.
Let me know what ya think? HG
Steel crank n rods
