I have a 1965 Plymouth Belvedere II, 273 V8 engine, automatic transmission, power steering, standard brakes. Engine was rebuilt 5 years ago, electronic ignition, new be cool aluminum radiator, everything else stock. Car is well maintained. Coolant changed out ounce every two years, 50/50 antifreeze and water. No problems for 5 years. New water pump when engine was rebuilt 5 years ago.
Recently the engine over heats after you drive the car about 4 miles. On a cold engine i pulled the radiator cap off, started the engine, let it warm up, and checked for bubbles in the coolant. None. Also there was no loss of coolant. Turned the heater on and it worked fine. Checked the fins in the radiator, belt, pulleys, and hoses and all looked good. Drained the radiator and caught the fluid in a jug so i could examine for contamination. Did not see anything. Poured the coolant thru a cloth and did not pick up anything at all. Engine starts right up and runs smooth. When i had the cap off the radiator, i speeded the motor up and got an increase of water flow thru the flutes in the radiator. This is a cross flow radiator so this was easy to check. I ran the car on a test run with no thermostat and the car still over heated.
I am running out of ideas. Anyone know what I should do next? Thanks
