1 - 6 of 6 Posts
Swapping a 4.6 ford into a 1974, Maverick?
Motor Mounts and tranny?
Or use a 302 instead, less work but alot heavier.
Some got some advice?
Thanks,
Cheffer
From my perspective, it gets down to what you want and why. If your intention is to put a 460 label on the fender so that everyone knows you have the baddest motor, then put it in there. If you just want to have a lot of power for the street, I would build a strong small block. The big motor weighs a lot more and there are lots of negative considerations around excess weight(and size) in the front of the car. You can easily get 300 to 400 hp out of a very streetable small block without and the project will cost you a lot less than messing with big block parts (they are all more costly). If this is your first engine swap, smaller and lighter is better.
Save a horse, Ride a Cowboy.
lonestarjim said:
I got it all done but the engine looks to low and viberates really bad. Can anyone help me?
You probably have a 5.0 and not a 302. They have different crankshafts and require different balanced flexplates and harmonic dampers. The 302 and 5.0 use the same motor and transmission mounts.
A 5.0 has a 50 oz balance.
A 302 has a 28 oz balance.
1 - 6 of 6 Posts
