1 - 6 of 6 Posts
Hi guys, I've got ticking sound from my Chevy 350 when the engine warms up. It's only really noticeable when accelerating. It isn't extremely loud, but i notice it over the normal valve train sound.
Instantly, I thought valve lash, but all appears to be okay when checked cold.
I did previously have an exhaust leak from pin holes in the header collectors, where the primarys join which we had to float some braise into to fill as couldn't get a welding tourch in to fill.
It does sound similar, but ide, expect the ticking to be present from cold if it was an exhaust leak ?
The motor is a built 357 with reto fit roller cam & roller rockers + the usual hop.up goodies.
Also I have noticed that the plugs on cylinders 7 & 8 cylinder are sooting up , but all others are burning perfectly. I don't know if this could be related or a separate issue ?
If anyone has any.thoughts or suggestions, they would be very welcome.
Thanks
Sent from my SM-G991B using Tapatalk
I once had a ticking that I couldn't find. Adjusted the valves several times, changed exhaust gaskets but the tick was still there. Wasn't until the cheapo chrome crank pulley broke that I found the tick. Seems there were cracks between the bolt holes and the pulley would flex causing the ticking (until it broke off). Just one thing to check and eliminate.
Had mech fuel pump that sounded like a knock when going bad. Also bought a vortec 350 that it sounded like exhaust but turned out to be the front cam bearing.
Are you sure it's not in the drivetrain then?
Cam bearing vid
Hi guys , sorry for slow response, had to put stuff on hold with work.
So I had a good look at the car when I did an oil change . I found the rear two intake bolts had worked slightly loose , but more likely a cause was a small crack & pinhole in one of the header primaries. This was only visible when I reved the motor & caught sight of a brief flicker of exhaust flame from a certain angle. Will hopefully weld it up over the weekend.
1 - 6 of 6 Posts
