I have a 326 in a 65 tempest convertible with the 2bbl heads (which are 9.0:1 by the way, the 4bbl heads were 10:1 in 65). It has been bored .030 over and has a slightly radical cam. I did not do the motor so I'm not sure what the cam numbers are. I also have an Edelbrock Pontiac Performer intake, a Holley 650 carb, headers, HEI ignition, 350TH tranny with street/strip shift kit and a 12 bolt 3.26:1 posi out of an Olds 442. I have never run it at the track, but its NOT a real screamer. It will smoke the tires with a little help from the brake, and it will catch second gear scratch. It sounds awesome and obviously runs better than a stock 326, but I am always looking for a deal on a 400 or 455! If you have a good bottom end already and want to pump it up, you may want to find a good set of the high compression 6X heads. Carefull though, because they made the 6X's in 2 different chamber sizes. Don't remember what the 4bbl head casting numbers were for the 326 right off, but this is a good link for Pontiac stuff. <a href="http://www.performanceyears.com/cgi-bin/ubbcgi/ultimatebb.cgi" target="_blank">http://www.performanceyears.com/cgi-bin/ubbcgi/ultimatebb.cgi</a>
Later
tom
Out
[ January 23, 2002: Message edited by: tsorens ]</p>
