south65ss said:
Cobalt327: the head was ported and has big springs and stainless valves and the work was done by a good machine shop, so I want to belive the problem is not there.
I understand that you don't want to believe the problem's there. But it still could be.
Are you using a mechanical advance distributor? If so, the weight/spring combo could be right on the verge of advancing, causing the timing to vary at that idle speed. If you suspect this might be the prob., temporarily install a heavy spring on one side and see if the vacuum stabilizes.
TI's advice is sound (as usual), try more advance if your gas will support it. Is the octane measured by MON + RON x .5?
Just as important as timing, is the fuel/air ratio. If it's off by much at idle, you can get erratic readings. But usually NOT a such a variation, like you describe. Bad carburetion will usually just be a low vacuum reading, but steady, for the most part- not quickly jiggling, like w/a bad valve, etc.
