Was wondering if anyone could give an power estimate on the engine I built?
355cid stock deck
Stock vortec heads 062
4vr flattop pistons sealed power H345ACP
rv cam .422in .444ex dur 204in 214ex @.050 with 1.5ratio
1 5/8 long tubes with 2.5" tru dual pipes and glasspacks
Edelbrock performer intake with edelbrock 1406 carb
stock crank and rods
hei ignition set at 32* max with vac can
I'm running this with stock stall thm350 and 2.76 rear gear 85c10
maybe CR estimate? What octane gas should I use?
Was wondering how much I will gain by adding 1.6ratio roller tips. Also is there any way to look for detonation without pulling heads or pistons, with the glasspacks I can't hear anything, I'm worried about too much vac advance.
I'm assuming a head gasket that is .039 inch crushed and a deck clearance of .025 inch which gives a static compression ratio of 9.7 which should be generally acceptable with an iron Vortec L31 head.
This is a pretty decent build except for the cam and gear ratios. The cam is one of those RV cams which in many ways are the rampy designs of the 1950's and 60's. While these wear well especially with today’s low to no ZDDP oil additives and they have a really nice exhaust note, it's hard to make modern power from them because in addition to low lift that doesn't take advantage of excellent flowing ports in modern heads, it holds the valves off their seats for a long time on the ramp. You will note the all important closing point of the intake has a 42 degree difference between seated at 71 degrees After Bottom Dead Center (ABDC) and the .050 inch of lift 29 degrees ABDC. So it's using 42 degrees to close that last .050 inch of lift. A 1.6 rocker will only make this worse by holding the valve open another 7% of lift while it's bleeding off cylinder pressure.
The issue is the difference between the Static and Dynamic compression ratios. What the Dynamic Compression Ratio (DCR) measures is the bleed off of mixture as the rising piston pushes it back into the intake until the intake valve is seated. Granted with the valve only open .050 inch there isn't going to be as much compression loss as if it were open further but still the rising piston on compression is putting a lot of backward force on the mixture which will become a high pressure bleed back into the intake till the valve is fully seated. When I run my DCR model (I'm also assuming you used a 5.7 inch connecting rod) at the fully seated value of 71 degrees ABDC the DCR is only 7.38 to 1. Using the .050 value of 29 degrees if it were seated at this point which it isn't the DCR would be 9.33 to 1. If I average these under the assumption that by .025 inch off the seat can flow damn little reversion so the chamber is building compression I get 8.4 DCR. This is a pretty good number where the 9.33 would be high and the 7.38 is way too low. However most engine designers don't consider the valve closed till the crank degrees come up with the valve .006 inch off the seat. So my averaged DCR may be optimistic.
This says a few things:
1) You shouldn't be experiencing detonation with this set up if my dimension assumptions are correct, you could safely push 2 to 4 more degrees of timing advance.
2) 1.6 rockers would possibly worsen the DCR by holding the valve higher from the seat during the ramp process, although it’s dropping faster so this might wash out the effect of being more open while on the ramp.
3) With your gearing the engine turns too slowly to develop enough mixture velocity to overcome the reverse pumping in normal driving, this is costing you power it's not making and fuel it throws away without using.
I'd recommend a faster cam like Comps XE series or Lunati's Voodoo. A 1.6 rocker works well with these as they don't spend so much ramp time between .050 and .006 inch lift as does the cam you have. So the DCR comes up. But these are harder on wear issues so you've got to be really careful about following the break-in procedure and additives list.
The 2.76 gears with a TH350 are too high; this is a good gas mileage, low emissions ratio that is OK if all you do is drive freeways at 70 mph or better. But for coming out of the hole or cruising town this just isn't the best way to go. A 3.08 with a 700R4 would be a better combination for both in town/drag strip and freeway driving.
I'd say this combination because of the cam and the less than optimium Performer intake this would be about 330 horses on an engine dyno. The intake also needs to be the Performer RPM. Why Edlebrock continues to sell the Performer is beyond me.
