Can I apply Evercoat rage filler over Nason 2K urethane primer? Or will I have to sand down to bare metal then apply filler? Thanks.
amanderson said:Can I apply Evercoat rage filler over Nason 2K urethane primer? Or will I have to sand down to bare metal then apply filler? Thanks.
If you sand the epoxy with 80 grit, won't most of the epoxy be sanded off?Rag top bird said:I have worked in many shops where thay apply filler over primer if it is sanded with 80 grit just make sure the primer has had time to cure before applying the filler
