I have a 700r4, aluminum driveshaft,new u-joints,9 inch ford,3.70 ring & pinion,auburn posi,30 inch tall tires. With the car changing from power on to power off (coasting), I hear knocking sounds from under the car.When I put it up on jackstands,in park, I can rotate the wheels back and forth about 20 degrees or so. It makes a nasty klunk when shifting from drive to reverse, and vise versa. Is this normal.
