basic physics
Air traveling thru a ventury has to increase in speed and the pressure decreases..PVT = a constant. change one and the others balance. A teter totter effect if one goes up the other has to go down. with the lower pressure in the Venturi it creats a "suction" It sucks the fuel into the Carb. With A lower fuel level It would require more suction to lift the fuel. With a constant flow of air it will not suck as much fuel per the amont of air. With a higher fuel level the it can suck in more fuel for the same volume of air.
