lights
Hi, Congrats on saving a Bedford (check my pics to see my JO Bedford truck- just click on the pic under my name on the left of this post) what sort of lights you wanting? Hella do a vast range of roof mountable lights and also the marker lights as used on the sides of trucks look good mounted down along the sides of a van especailly if you add some alloy running boards. If you want neon lights for the undercarriage then Halfords probably have those too. Just hook into your sidelights wiring with a connector for the positive power and earth them out through the steel body. I used to have a CF with running boards, lights, lake pipes, rear door welded and bogged, tinted side windows, custom paint. It had a 6 cylinder GM Holden engine and trans but original 4 cylinder diff so it went like snot and could do good one wheel burnouts!good luck
