1 - 2 of 2 Posts
I gotta 1955 F100 with a Gibbons/Cordoba front suspension under the front. My question is if anyone other that Fatman Fab sells drop spindles for it? They are charging damn near $500 for them. Id like to get them so I can properly lower this thing instead of just letting down the torsion bars. My other question is if anyone is running this set up, Id like to see some pics of the steering set-up. Thanks let me know if you can help.
i have a volare under a64 f100/same problem no suspension travel when at lower-look good ride height.i cut back rubber bump stops-helps. i halve a manual box-p.s. box weights about 50 lbs.-use box out of a 72 charger-used 2 u-joints from a escort and shaft-used tilt column from 76 ford ltd -filled in switch on column-used sealed bearing bottom of column-made strap to mount bottom of column to cab-used turn signals. i need a quicker steering box-flaming river box $420-any help ?
1 - 2 of 2 Posts
