cool I could post some pics later on once its a bit more complete but , basically involves fabricating a tuned length manifold from scratch ,and using "donor" parts ie injectors coil packs etc and a aftermarket ecu , Im going to use a link ecu( made in NZ) so far I have the basic manifold made just in the process of adding fuel rails etc etc , but its going to take a while, its going to cost around $1000NZ for the injectors/coil packs/throttle bodies etc , the ecu is around $1500NZ so its not to bad , current calculations should be getting around 300+ Hp out of the ol 253 Holden cast 8, basically I wanted something different and wanted to retain the factory option Holden engine (was a 1900cc 4 originally) ,so I decided to fabricate it from scratch to my own design (with help from a friend whos done similar for sprint boats )instead of adapting a later model tpi manifold ,but not much is going to be factory
The fun part is calculating expected flow rates needed for the injectors ,pump etc and throttle body sizeing,
So far the car has had the drip rails shaved and front preped but still requires a rebuild of the rear guard archs (it had had glass flares fitted and the arches cut up for tyre clearance )but Im now shortening the diff and returning the arches back to standard .
The engine is out at the moment awaiting a rebuild once the manifolds have been fabricated .
mmm I think I might have overdone this post but enjoy the reading
Cheers
Dale.
