1 - 1 of 1 Posts
This is a lightly used Fuel Air Spark Technology (FAST) brand EZ EFI 2.0 multi-port, self-tuning engine control system for electronic fuel injection. See this exact system at:
https://www.fuelairspark.com/ez-efi...control-system-multi-port-retro-fit-type.html
It was briefly installed by the prior owner into a project car I recently bought. The car still needs a lot of body and other work and was never made fully road-ready. So the system saw virtually no use, maybe 30 miles of test driving. Now that I have the car, I am taking the engine in a different direction, and I just don't need this spare EFI system sitting around. I will be moving soon and need to reduce the clutter.
The FAST system works with 4-, 6- or 8-cylinder engines. It is often used to replace carburetors. FAQs on the system are at:
EZ-EFI Frequently Asked Questions | CPG Nation Forum
There is nothing wrong with the system; it functions normally. I can provide a video I shot showing the installed components and the car starting and running smoothly before I pulled the system.
This package includes:
*ECU
*Touchscreen handheld controller w/ mount
*Wide-band O2 sensor
*Wiring harnesses: including main/engine bay harness, handheld controller harness, with connectors installed (injector connectors, O2 sensor connector etc.)
*Fuel pressure sensor and mounting block
*Installation manual and wiring diagrams
I am also including:
*A FAST IAC (idle air controller) with mount and mini air filter, and another backup IAC
*Air temp sensor
*Coolant temperature sensor
*Throttle position sensor
My price is $625 cash, no trades, I will not ship it. Sold as-is, no warranty etc. Located in Las Vegas. As in the link above, the system sells new for $1300 + shipping, plus you would have to source the sensors and IAC, which you need.
1 - 1 of 1 Posts
