I had some trouble with my 355 running hot, above 210degrees. I thought of all the different possibilities, but when I took the heads off to do something else, I noticed that the fel-pro gaskets had punch-out things that made the coolant passages larger, to match the size of those in the heads. Those were not punched out so there was only a 1/8" hole allowing the coolant to flow to the heads through. Is that my problem? Should those be punched out?
