now from your stand point in having used diffrent systems what would you recommend for a weekend cruiser occasional daily use and maybe a few runs down a 1/4 mile? I just want something i can hop in and go drive around all day have some fun and is not a pain in my butt to get going and get decent performance from.
I converted my Pro-Flo 3500 to the Holley C950 EMS. You can read about it here:
http://www.edgesz28.com/edgesz28/fuel.htm
I've used both and would definitely recommend the Holley over the Edelbrock. The Pro-Flo 3500 is $2,160 at Summit and the Commander 950 is $2,300. Both provide everything needed, except with the Holley recommends a small cap HEI distributor (not included). The Edelbrock has a cheap Hall Effect distributor conversion setup. The Pro-Flo ignition amplifier is nothing more than a HEI module in a red box. The Holley system also gives you the option to add Wideband later if you want.
I don't want to slam the Pro-Flo too much, but having the C950 control my Pro-Flo has made tuning a breeze. Tuning with a laptop is better (IMO). The handheld control module has screens that you need to scroll through (in and out so to speak). Whereas the C950 has all the RPM and load cell points on one fuel map screen. The cell pointer moves around the various cells as you are driving. If it a particular cell is reading lean, add a little fuel. If it is rich, take a little out. Within 30 minutes of driving, I had my 383 tuned for normal driving conditions. With the Pro-Flo, you don't have this ability.
With the Holley you can get the single plane version (like the Pro-Flo) or the Stealth Ram. The additional $140 is well worth the extra expense.
Good luck, Ed
www.edgesz28.com
