All this conversation about scopes and diagnostics brought back a memory of a weird problem I had and never got to figure out, as the customer bailed out on me. One of the few that got away.
It was a 79 Ford 302 with a definate miss. I isolated a dead cylinder with a cylinder kill test. The ignition checked out fine although the firing voltage on that cylinder was a little low. Even with new cap, rotor, wires and plugs it was still low. I did a compression test suspecting a burnt valve but the cranking compression showed all cylinders to be within 10% from high to low which is well within specs. Finally I left the compression guage in the dead hole and fired the car up. When I released the compression that it had pumped during cranking it would only pump back to about 35 psi with the engine running. I checked for a broken valve spring or bad cam lob and found neither. At this point I had three hours into it and the customer didn't want to spend any money on the car and bailed out on me. I never did figure that one out. Any Ideas? BTW I think the low firing voltage was only due to the lack of compression. It doen't take as much juice to fire a plug that isn't in a compressed atmosphere.
