What do you do when you see the first signs of rust?
I can see the metal cancer beginning to show up in several areas. Mostly small crevices or in locations which make repair difficult, impossible or too time consuming to contemplate. Just shoot the area with a rust killer and protector like Fluid Film or Rust Check?
Just shoot a little spray paint over it to hide it?
Or should I think about sandblasting the area and using a little POR15? The trouble with POR15 I find is that often the source of the moisture is the other side of the repair and the spot eventually rusts again anyway. Also sandblasting is such a mess.
