leastbay said:
once i get it smooth will it be worth it to shoot a clear over it? or would i have to do it within a certain amount of time? also what could i use
If its in the budget not only good experience (it will spray same as your enamel) But will make job look good.
As long as you activated the enamel you can do it anytime from the next day on.
Wet-sand with 600-1500 your choice, wash with wax and grease remover and shoot.
You can use any urethane or Polyurethane type clear and any brand at this point.
If the paint was not activated the only thing you can use is an enamel clear with no activator and i don't know that even exists today.
