Hey guys looking for some input and help on the way to repair some rust on my DD. Not having experience here is what I am planning on doing and please let me know otherwise. In front of the tire I am thinking of replacing the entire area with the patch panel. Cut along the top, probably have to drill/grind out some plug welds inside the door jamb, and cut it along the bottom. Then weld in the new piece with a couple plug welds in the jamb and seam sealer afterwards, and butt weld the rest of it in. Or is there an easier/better way to do that? Or should I only do a little more than the rotten areas? I understand to tack it in and let it cool and do that slowly as to not warp anything. Is it better to butt weld, or can I lay the seam under the body slightly and weld there, then use a little more body filler. After cutting the sections out, what should I apply on the backside of the panel and inside the rotted areas to help seal it better? Understand that I am trying to get it to last and look good while learning to do it myself. Thanks for any input.
Here is before I hit it quickly with a wire wheel to see what it was really like.
P.S. The body moldings will be removed so I can't hide a seam under them afterwards
