1979 Chevrolet Malibu 496-TH400-9" (cruiser). 1992 Chevrolet S10 355-700r4-7.625" (daily driver).
The short answer is no. If the consideration of "the same specs" is based on using only the commonly used advertised duration @.006" lift, duration @.050" lift numbers and the total valve lift numbers typically used to identify and/or compare camshafts to one another would look like this:
The 2 compared cam lobe profiles here would share the same often used numbers seen in the retail catalogs (i.e. Summit Racing, Jegs).
This illustrates the point that the basic numbers don't tell the whole story because of the difference in the shapes of the cam lobes. Technically you're not going to find a flat tappet and a roller cam that truly share the exact same specs. From a catalog listing, you can see the .006" and .050" durations will be the same. The total lobe lift is also the same. As shown in the graph, if you try to compare specs anywhere outside of the catalog listed numbers...the specs won't truly be the same.
The "area under the curve" shows the additional flow the roller profile has compared to the flat tappet profile sharing the .006, .050 durations and total lift. The roller profile will outperform the flat tappet.
It's worth noting that the additional "area under the curve" with the roller profile makes the cam "act bigger" than the flat tappet profile. If both profiles share the same "212 degrees @.050 duration" the roller cam acts 6 to 8 degrees longer than the flat tappet would. Sources vary on the difference but 6 to 8 degrees @.050" seems like a commonly used comparison. So, if you had a 220 @.050" flat tappet and you wanted to keep similar RPM ranges, you would choose a roller with 212 to 214 @.050
Keep in mind that the graph is still very crude in its demonstration and this is a generalized viewpoint. It's made the way it is for simplicity. That graph, while good for this discussion, shows the relationship of long ago outdated symmetrical cam lobe profiles.
The folks that really know this stuff better may chime in and correct anything here. I'm at a hobbyist level of understanding and not even close to what the pros know.
