Hi,
I'm trying to understand the trany gear selection as described in the owner's manual for a 1996 Geo Tracker. I will be towing it 4 down, behind my motorhome.
The owner's manual says to put trany in second gear, transfer case in neutral, key on. I put in a battery disconnect so I don't run that down.
Manual also says to stop every 200 miles and run the engine with trany in second gear, transfer case in neutral and "clutch engaged".
I'm wondering why not just keep the trany in neutral while towing.
I can see that running it periodically would help keep the drivetrain lubed, but a little confused on the "clutch engaged" wording. Does that mean clutch plate engaged, or the clutch pedal engaged/depressed.
Running with clutch plate engaged (pedal out) would turn the countershaft and lube the internals and would spin the transfer case and lube it also, so that's probably the right way, but why run it in second gear? So the output shaft turns also and spins the transfer case? But isn't the transfer case already turning from the driveshafts?
Thanks.
Thanks.
