to start i was having some issues with my starter which a starter brace fixed.
the remaining problem is it chewed up the starter ring gear on my flexplate.
if u were to measure were it ground the teeth off id say its aobut a 4inch long section the rest of the teeth are fine.
normally id would just install a new flexplate and be done with it but the problem i have is i just moved and cannot work on the car outside were i am and do not have access to a garage. so dropping the transmission is in no way possible.
ive actually had the car sitting cause of this.
so i had an idea well 2 actually
the first idea would be to crawl under the car with my mig welder and weld up the ground down teeth then file/grind them back to the right size and shape.
the only problems i have are the only welder i currently have is a flux cored mig which i suspect will make it alot harder to file and grind after i build them up with weld.
ideally for something like this i would use a tig welder but i dont have one and cant get access to one, though i could try some of the local auto shops in town but i dont think any of them have a tig welder
my second idea is i have a flexplate that i was going to install.
well why cant i just grind and cut the section of ground down teeth off and cut a section of the ring gear off the other flexplate and weld it on as a temporary repair until i can remove the trans to install my new sfi flexplate
or instead of cutting a section of the ring gear off my other factory flexplate i could buy just the ring gear from napa for about 10-15 bucks which i could cut a section out of to weld on
the flexplate that in the car along with my spare, the ring gear is stitch welded every few inches on one side only so i figure removing just asection wont be that hard
and again i know this isnt the proper way to fix it, but i have to do whatever i can to get some sort of solution for the time being, untill i can remove the flexplate and replace it with a new unit.
any ideas on which method would be best, or any other ideas on some sort of temporary fix would be greatly apreciated
