1 - 7 of 7 Posts
or Jeff, or Doc, or...
Overspray on floor
whats the best way to clean oversray off the shop floor ( single stage urethane)?? Short of mopping it with 5 gallons of laquer thinner, that is...
Do you want to clean the paint off to bare cement, or just clean the paint. To just clean the paint, why wouldn't soap and a pressure washer do it?
This should be moved to the garage forum.
Discussion Starter #3
Ponch- These guys do paint every day. They know what takes it off. The Garage forum does not.
I'm looking for an easy way to remove the paint from the floor.
Is the floor previously painted, besides the overspray? Mine was coated with a cheap epoxy paint when new. I get overspray on it all the time. Most of the time a good scrubbing with laundry soap will get MOST of it off. The rest wears off pretty quickly. Of course, spilled paint is a different story!
Aaron
Discussion Starter #6
The floor is just natural concrete with a curing sealer. About 4 years old. Its just overspray , but its pretty heavy urethane...
Just one of the guys
That'll give the new floor coating something to bite into!! :D Other than scrubbing or a floor polisher / sander you might pretty well be screwed. I would let it dry and maybe rent a floor scrubber with the scotch-brite pad and go over it using some TSP to see what that will do.
The natural concrete lets the paint bite into it beings that the sealer has probably wore off in that amount of time.
Kevin
1 - 7 of 7 Posts
