Status
Not open for further replies.
old dog learning new tricks
This leak is coming from either the top cooler line where it connects to the tranny or above that. I really can't see anything above that point and I've replaced the top fitting, including o-ring ect. What else is above this fitting that could be leaking?
It's a 98 Chevy Tahoe 4x4, 4l60e, ect.
I guess I'll take the cross member out tomorrow and drop the tranny down in order to try to see more. I was hoping someone has seen this issue and can guide me to a solution.
As always, thanks for any help!!!
Mike
well there is nothing above it,, un less your your trans is cracked around the fiting or the line it,s self has a small hole in it,, other than that the onley thing up there is the vent if that,s the case your trans is building up to much pressure on the inside,,
Your right. The case is cracked just to the rear of where the top fitting threads into the case. I cleaned it good with brake cleaning fluid then coated everything around that fitting with baby powder. As soon as I cranked it I crawled under with a telescopic mirror tool and identified the exact location. Then I cleaned it again and put 2 coats of JB Weld over the cracked area. It's holding good for now but I don't expect it to last. If not I guess I'll have to pull the tranny and transfer case and TIG weld the crack. There is not enough room to get a TIG torch and rod to it with it in the truck.
Thanks for your help s10mikey. :)
Status
