My engine is in need for a cooling system flush. Chevy small block, 1st gen 1992 model
If I remove the water pump, and opnes up the low located plugs on each side of the block, can it be a good idea to simply flush the block by using a garden hose in each of the water pump channel holes at the front of the block?
I do have a high pressure washer as well, but that might be to much?
