I have a general question about flycut piston valve reliefs.
Starting with flat top postions, I can find where valve relief cuts should be made using plasticine (modeling clay) on top of the pistons.
I read that closest proximity between valves and a piston with some cams is NOT tdc but might be anywhere between 10-20 deg after tdc on the intake.
I read that some people use the Isky flycutting tool and some people take the pistons to the machine shop. If I calculate the required distance using the clay, how do I tell the machine shop what angle to cut the valve reliefs?
