I have a fmx ford tranny in my 80 model truck , with 302 for power . the tranny has reverse an a little forward i low gear . know one has a repair manual for this transmission. does anyone have , any suggestions. thanks from alabama ford
80 t
80 t
The reason was capacity. As manuals went away and everything went automatic in the 70s and 80s -- especially trucks -- Ford couldn't build enough automatics. The C6 lines in Livonia were maxed out -- The C4 line in Sharonville was maxed out -- and the AOD line in Livonia was just launching and not up to capacity yet. The plan was to do away with the FMX, but as long as they needed more transmissions they kept the Fairfax plant alive. It finally closed in 1982.tnsmith10 said:get rid of the fmx and throw in a c-4... why they even bothered with the fmx in 1980 imho was a joke. even a small block c-6 would be a better choice... either would last if built right and would save roughly 100 lbs. if im not mistaken, the c-6 should bolt right in... no changes.only thing is, is the neutral switch... may have to do a bit of wiring.. that, and the kick-down rod adjustment.. :thumbup:
