Thank you Hot Rodders!
1966 Chevy Malibu
assembled in Fremont, CA
350 cu in SBC with four-bolt main caps bored .03 over
Holley 750 carb with vacuum secondaries
Edelbrock mechanical fuel pump
Dart Sportsman Intake Manifold
TRW cast pistons
X-rods
turned cast crank
Comp 270 cam
72cc Dart II Sportsman heads ported & polished
Doug Thorley thermal coated headers
Flowmaster mufflers with 2 1/4" pipes
TH350 Transmission with shift kit
B&M Quicksilver shifter with Hammerhead
1 1/8" sway bar with greasable polyurethane bushings and end links
centerlink, inner and outer tie rods, idler arm, right A-arm and shocks
Suspension Techniques coil springs
Energy Suspension polyurethane control arm bushings and bump stops
Core Support bushings with hardware
front disc brake conversion with booster, master cylinder and hoses
Hotchkis adjustable upper and lower rear control arms
rear sway bar
body mount bushings
Autometer tach, water temp, oil pressure and alternator gauges
Grant GT steering wheel
Flow Fit bucket seats
Centerline Terminator Wheels
Goodyear Eagle GT radial tires
