I am switching my 5.0 back to a mechanical fuel pump. I have a box with mixed Ford parts. I had parts for a couple 2 piece eccentrics, and one or two of the 1 piece designs.
I had to take my timing cover and water pump off to add a fuel pump eccentric. I opened up the front of the engine. I looked in my box of parts, and I used an eccentric that I thought was a one piece design. Then, I reassembled the front of the engine.
Now, when I spin the engine, there is very little fuel pump action. I put my finger over the vacuum side of the pump, and there isn't enough suction to maintain adequate pressure. I am using brand new stock pump.
I removed the fuel pump and moved the pump arm by hand. By hand, I can generate more than enough, so I would imagine the pump is fine.
Is there a way to tell if I may have used part of the one piece eccentric by mistake?
Could the new pump be bad?
I have to use a two piece eccentric. The Cloye's timing chain requires it.
Is there something I am missing?
