74 Mustang II, 2.3L, points type ignition. After aligning the cam timing marks (ohc belt driven cam) and setting the engine to TDC via the timing marks on the crank pulley (didnt verify #1 was at TDC, but with the cam marks aligned, #1 would be at compression and if #1 piston wasnt at TDC i dont think it would run at all) and setting the distributor to point to the #1 tower on the cap, the engine wont run. Rotate it 1/4 turn (all the way against the stop towards the firewall) it runs great...... but its not right. Why would it run good when its set to fire or two cylinders away from the one it should be firing? Do i not have the points set right or something? I'm confused... this is why i want an MSD ignition... points are not for me. I have two other identical cars, except they are 76s and 78s with electronic ignition 2.3s and they run good. The only difference is the points.
Im at a loss. This engine has never run right, when its cold and you rev it up it shakes real bad (you must rev it up and hold the rpms up for a while until it warms up or it will not stay running) and it has less power than the other two cars. This car has 3.55 gears and the other two have 3.00 and 3.08 gears. Theoretically this car should have more power, but it doesnt. Anyone got any ideas?
