I parked my car then came back a week later or so and tried starting it and it wouldn't start. It was having a hard time turning over so I checked some stuff and at first I thought it might be my batterie or starter being weak or something then I smelled too much gas and then figured out the crankcase was full of gas. So instead of oil circulating in my engine I had gas all in the gallies, oil pump, lifters, everything I assume. I drained the gas and changed the oil two times. And put in a new fuel pump. I primed the oil pump. I also broke the starter gear and the bent the pushrods. I understand why my starter gear is broken. Because it was too much resistance with the gas because it has a lower lubricity than oil but I dont understand why my pushrods are bent. The only thing that could cause that is valves sticking or valves hitting piston? Or could it just be binding? lifters too? At first I thought it was my timing chain so I replaced that with the sprockets. I was thinking maybe when I was turning it over when it had just gas in it the timing chain slipped? Making the cam off time and hitting valves on piston? I'm thinking I need to pull the motor out and overhaul the entire engine. I always have to learn the hard way I suppose. I will always replace fuel pump on older vehicles. Why would you separate the gas and oil by one gasket? Bad invention in my opinion. Not thinking in terms of reliability. I'm running electric fuel pump from now on.
I know 2 stroke dirt bikes run with gas going through crankcase but those have needle bearings. So are my shell bearings probably toast?
