406, how much hp?
From what I can come up with, they put out 360 hp, but that can be misleading as they put out 480 lb ft at 2200 rpm. Maximum stump pulling at its finest, this with a 4 bbl carb.
In 72, Ford went to differential horsepower instead of flywheel ratings and the 460 was rated at 200 or 212 hp, depending on whether it was the standard 4 bbl or the police interceptor version. Remember that along with the change in horsepower rating, also came dramatic drops in compression ratio and severe retarding of camshafts to meet smog standards of the day. This acounts for the drastically lower figures. To figure what the flywheel hp of the differential rated engines might be, add 50-60 hp, that will get you close.
