fredbaker said:
I have determined that my 9" has the early big bearing ends with 28 spline axles. The bolt pattern on the ends is correct for the early ones but the shape of them is identical to the later " Torino ' ends. The only thing I have found is some aftermarket old style ends that match mine so maybe this rearend has been narrowed before. I will have Moser weld on the later style ends so that I can install Explorer disc brakes and re-machine the wheel bolt pattern for the 5 X 4.5 pattern as this seems to be the most popular pattern and I already have a set of Crager SS 10" X 15 mags to match the front 5" X 14 .. A set of 2 Cragers are $400.00 these days.....
Glad you made some progress... I'm really at a loss for why they're shaped like Torino ends, but maybe they were produced like that at some point. I honestly don't know!
Are you having Moser narrow the housing and the axles? I don't know that they'll be able to narrow the 28 spline axles. How much narrower are you going? You may end up having to do custom axles...
When you have them do all this, make sure you tell them what brake setup you're going to run so they can figure all that into the equation. The early big bearing axles ran a "brake offset" of 2.375" while the explorer requires 2.5" offset. On that note, ask them if the spacer is needed as well. They should know what you're talking about, but it's basically a spacer that goes between the bearing and the axle retainer to account for the difference in drum backing plate thickness vs. disc backing plate thickness. It's the "preload spacer" in the speedway directions that I posted.
Also, check the axle register diameter to make sure it's less than the rotor opening diameter. I had to shave mine down a little so the rotor would fit on the axles. The opening is 2.800".
Did you decide if you're going to pull the brakes from a junkyard or are you buying the kit from somebody like summit or speedway?
Again, if you have any more questions or need pictures, feel free to PM me or add to this thread. Good luck!
