I'm putting the axles into my Ford 9 inch rear end (road race stock car) with a new 9 inch center section. I've got an assortment of axles that came with the car. They all have bolts in the end of the axles that go into the center section. And they each have a little bit different stack of washer shims.
I figured this is to set how much clearance there is for the axle to float horizontally between the stop inside the center section and the cap that goes on the outside of the wheel hub.
How much clearance should I be looking for here?
Thanks!
Thanks!
