After finally putting my new center section into the housing and filling the diff with gear oil I discovered an oil leak. Inspection revealed that the leak is not coming from the centersection/housing interface but from the nose of the center section. It's not from the pinion shaft oil seal but from the "cover plate" that bolt to the nose of the cernter section. So I need to pull that cover plate off to reseal that joint. Is it possible to pull the cover plate off without tearing the whole diff apart to reseal the nose?
