Thanks fo the informatio.All I can tell you is the "2 L .75 9" is 2.75 ratio with the "L" denoting Locking rear, most likely the Traction-Loc. 9".
Others may be able to tell you more.....I know just enough to decipher the important part of the tag while salvage yard hunting.
So how do I check to make sure this does or don’t have the bigger gear set?some of the lincoln came with a 9 3/8 gear set some parts interchang
e and some pumpkins don't fit in early ford housings
I bought a ford 9” rear end, no idea what model or year it came off. Hoping someone can help with the numbers on the tag, the top row has: WFY-A5 3KC
then the bottom Ron has 2 L .75 9 4808. Thanks
the 9 3/8 has a droop in the top rib.
No, you cut the housing ends (axle bearing housings)off, then cut the open end of the tubes to the width you want and weld the refurb'd or a new set of housing ends(bearing housings) back on.Sorry, added a couple of picture, the doesn’t look like it has a droop to me, also I notice on the axle housing it has weld on both side, looks like you could could change the with there. Not sure?
Thanks, i think I’ll start looking for parts that will work for the width I need.No, you cut the housing ends (axle bearing housings)off, then cut the open end of the tubes to the width you want and weld the refurb'd or a new set of housing ends(bearing housings) back on.
I requires an alignment jig if you want it done right.
Don't cut the tube at the weld where it meets the center housing "banjo".
